ERROR - Maximum Number of POI's
Begonnen von Ewout, 25. September 2008, 12:04:38
Ewout
Sorry that i type in English, but my german is not to good.
I am using: Biviator PLC and/or Wago PLC with CodeSys 2.3
For some reason when i load the library in CodeSys i get the error Maximum Number of POIs (512).
I donââ,¬â,,¢t even have to use a item out of the library, only putting in the library is enough to get the error.
Does anyone have a clue why or how to solve this?
I really would like to use the PID controller in this lib but i cant even try it  :o
go to yout target setup
under memory or adress setup you will find
max number of POI change this value to 1023 and you should be find
michael.stutz
Hello Ewout
For Biviator PLC. You will have to take the used POUs out of the oscat.lib (export) and import it to your Project or .lib.
For other Solutions feel free to contact us:
info@biviator.ch
