Hello community OSCAT.
I found a algorithm at http://homepage.smc.edu/kennedy_john/DEC2FRAC.PDF which can be used to convert any decimal number in a fraction.
I needed this solution, because I use MOVIDRIVE from SEW-EURODRIVE to control aplications such as Flying Saw to cut materials during synchronized moviment.
The problem is that the ratio between master and slave must be adjusted in two variables or parameters of Movidrive named GFMaster and GFSlave which works as a fraction.
With this algorithm I rewrote a function block below that cam be used for this purpose.
I made some tests with it running in MoviPLC model DEH41B from SEW and worked very well.
I would be grateful if this function can be added in the next revision of the library Oscat.lib
FUNCTION_BLOCK REAL_TO_FRAC
Decimal: REAL;
AccuracyFactor: REAL := 5.E-007;
Numerator: DINT;
Denominator: DINT;
DecimalSign : REAL;
Z : REAL;
PreviousDenominator : REAL;
ScratchValue : REAL;
FractionNumerator: REAL;
FractionDenominator: REAL;
IF Decimal < 0.0 THEN
DecimalSign := -1.0;
ELSE DecimalSign := 1.0;
END_IF
Decimal := ABS (Decimal);
IF Decimal=D_TRUNC(Decimal) THEN (*handles exact integers including 0*)
FractionNumerator := Decimal*DecimalSign;
FractionDenominator := 1.0;
RETURN; (*EXIT;*)
IF (Decimal < 1.0E-19) THEN (*X = 0 already taken care of *)
FractionNumerator := DecimalSign;
FractionDenominator := 9999999999999999999.0;
RETURN;
IF (Decimal > 1.0E19) THEN
FractionNumerator := 9999999999999999999.0*DecimalSign;
RETURN;
Z := Decimal;
PreviousDenominator := 0.0;
REPEAT
Z := 1.0 / ( Z - D_TRUNC( Z ) );
ScratchValue := FractionDenominator;
FractionDenominator := FractionDenominator*D_TRUNC(Z)+PreviousDenominator;
PreviousDenominator := ScratchValue;
FractionNumerator :=D_TRUNC(Decimal*FractionDenominator + 0.5); (* Rounding Function *)
UNTIL (ABS((Decimal-(FractionNumerator/FractionDenominator))) < AccuracyFactor) OR (Z = D_TRUNC(Z))
END_REPEAT;
FractionNumerator := DecimalSign*FractionNumerator;
(*These last lines where used only to convert the output variables in double integer*)
Numerator := REAL_TO_DINT(FractionNumerator);
Denominator:= REAL_TO_DINT(FractionDenominator);
ZitatI would be grateful if this function can be added in the next revision of the library Oscat.lib
thank you, that we do
Correction:
I made a mistake when I wrote the last lines in this code.
To this function block be able to calculate fractions of integers numbers including the zero. Is also necessary to put that last lines in other parts of the code.
Following, you can have the revised code and also download the export file of it.
Sorry for my falure.
Decimal: REAL;
Numerator: DINT;
Denominator: DINT;
DecimalSign : REAL;
Z : REAL;
RETURN;
RETURN;
RETURN;
Z := Decimal;
REPEAT
END_REPEAT;
