oscat.lib => Bestehende Module / Existing Modules => Thema gestartet von: Strucc in 19. Mai 2011, 07:51:07
Titel: Minor bug in RTC_2 FB
Beitrag von: Strucc in 19. Mai 2011, 07:51:07
While implementing SNTB based time synchronization I found a minor bug with the DST offset calculation:
Line 9-10:
(* calculate time offset and set ldt output *)
LDT := DWORD_TO_DT(DT_TO_DWORD(UDT) + INT_TO_DWORD(ofs + BOOL_TO_INT(DSO)) * 60);
Should be:
LDT := DWORD_TO_DT(DT_TO_DWORD(UDT) + INT_TO_DWORD(ofs + (BOOL_TO_INT(DSO) *60)) * 60);
This was within library for CoDeSys 2.
By the way thanks for all the ideas and work within these libraries: really great and useful stuff. I'm looking forward to contribute.
P.Peter
Titel: Re:Minor bug in RTC_2 FB
Beitrag von: Strucc in 19. Mai 2011, 08:20:11
By the way, it  could be more correct to reuse the UTC_TO_LTIME function:
LDT := UTC_TO_LTIME(UDT, DSO, OFS);
