oscat.lib => oscat.lib fuer TwinCAT/CoDeSys => Thema gestartet von: xroi in 01. August 2011, 08:03:44
Titel: ABB AC500 PM582 V1.2
Beitrag von: xroi in 01. August 2011, 08:03:44
Hello!
I'm using ABB controller AC500 PM582 (Target version V1.2). CoDeSys v.2.3.
There are a few things that you can help me.
1. oscat.lib takes too much POU's - and I can't enlarge them! Request sent to manufacturer.
2. In oscat.lib library there are repeated elements like in the standard libraries, for example, INT_To_BCD, BCD_TO_INT (look at util.lib). So, it's necessary to delete something... :( :( :'(
What to do?
Is it possible to divide the oscat.lib library into several small and simple libraries, which can be efficiently used?
But if you have interesting and cool solution please help me...)))
Titel: Re: ABB AC500 PM582 V1.2
Beitrag von: hihi in 18. Januar 2012, 18:35:06
I've the same issue, maximum number of POUs exceeded ...
Would it be possible to split up the lib? or is there a way of disabling some of the POUs which I don't use?
thank you for the support
Beitrag von: hihi in 18. Januar 2012, 20:25:28
Hi All,
Got it, I've found a way to disable the POU's I didnt use ... newbie ...
cheers,
