Hi!
I just want to inform you that the BLIND_SHADE_S have a VAR IN/OUT failure:
ZitatQU BOOL VAR_INPUT 0 0 0 0 0 0
QD BOOL VAR_INPUT 0 0 0 0 0 0
STATUS BYTE VAR_INPUT 0 0 0 0 0 0
PO BYTE VAR_INPUT 0 0 0 0 0 0
Should be:
ZitatQU BOOL VAR_OUTPUT 0 0 0 0 0 0
QD BOOL VAR_OUTPUT 0 0 0 0 0 0
STATUS BYTE VAR_OUTPUT 0 0 0 0 0 0
PO BYTE VAR_OUTPUT 0 0 0 0 0 0
Isn't it?
EDIT:
OK, there are some more failure in this function block.
I attached a version what is compiling - but I didn't test it 100%
