Hi all, and apologies, I am not a German speaker. I am trying to import OSCAT network lib into KW MultiProg 5.47 (latest). It will not compile because it cannot find IP_CONNECT and three other funtion blocks. I assume these maybe are present by default in PCWorx, but may not be in Multiprog (though I thought they were the same?). Does anyone know how to solve or code around this issue in Multiprog?
Thanks to all that contribute to OSCAT-!
Bob
at least I can confirm your assumption that IP_CONNECT is part of the standard Functions of PC WORX. I do not have installed any related, Phoenix Libs., but IP_CONNECT is on my PC in PC WORX EXPRESS.
I wonder whether it might be possible to create a small Library from free PC WORX EXPRESS containing the required functions?
CU
Rainer
