network.lib => Codesys 2 => Thema gestartet von: dhautomation in 21. Oktober 2013, 16:12:46
Titel: OSCAT IP_CONTROL2 Lib. SYSLIBSOCKETS_OPTION not present
Beitrag von: dhautomation in 21. Oktober 2013, 16:12:46
Hello
I'm new on this forum so sorry for my possible failures;)
I have i problem with an OSCAT lib, IP_CONTROL2.
When i build my program there is still a message:
Error 4001: IP_CONTROL2(142): Indentifier 'SYSLIBSOCKETS_OPTION' not defined
How can i solve this?
I think this is the reason my program is not working.
I try to build a program that can communicate whit a remoteI/O trough TCP/IP?
Maybe you have some hints??
Thank you!!
Titel: Re: OSCAT IP_CONTROL2 Lib. SYSLIBSOCKETS_OPTION not present
Beitrag von: peewit in 21. Oktober 2013, 16:36:10
'SYSLIBSOCKETS_OPTION' is a global variable from the oscat network bibliothek
