Hi all!
i'm newbie in codesys and oscat library, but i have to communicate my PC's program with PLC via TCP/UDP(look at picture)
So i can send data from PLC every 10s(look at attached picture on ctrl_pwm), but i cannot receive data. Please tell me, where i did mistake?
thanks a lot!
it is not possible to program a clean program in kop or fup
you must programm your module in ST (strucure text)
the ip_control block has a state machine
1. connect
2. send data
3. receive data (alternately to send !)
4. evaluate and acknowledge error and reconnect....
watch the blocks in the network library (directory 'demo') , there are some examples
or
ok, but here http://www.oscat.de/community/index.php/topic,1071.msg6404.html#msg6404
only examples Telnet Send, but i have problem with receive data.
tell me please, can i use Modbus Client and Server function blocks for send/receive via UDP protocol ?
am i right that for receiving data i have to:
ip_c1.mode:=3;
ip_c1.enable:=true;
ip_c1.time_reset:=true;
ip_c1.r_observe:=true;
r_buf1.size:=0;
yes, you can use the code from modbus client/server
ok, i write program in ST, can you tell me where i did the mistake? thanks..
CTRL_PWM(CI:=0.5,F:=1);
IP_CONTROL2(IP_C:=IP_C,S_BUF:=S_BUF,R_BUF:=R_BUF);
CASE state OF
0: (* On Wait for release *)
IF CTRL_PWM.Q THEN
state := 10;
IP_STATE := 1;(* Sign on *)
10: (* Wait for clearance to access for connection and sending content *)
IF IP_STATE = 1 THEN (* access permitted? *)
(* IP set up data traffic *)
IP_C.C_PORT := 1201; (* enter port number *)
IP_C.C_IP := IP4_DECODE('192.168.0.5'); (* Enter IP *)
IP_C.C_MODE := 1; (* Mode: UDP+ACTIVE+Port+IP *)
IP_C.C_ENABLE := TRUE; (* Release connection *)
IP_C.TIME_RESET := TRUE; (*Reset TIME monitoring * *)
IP_C.R_OBSERVE := TRUE; (* Monitor data receive *)
R_BUF.SIZE:= 0; (* Reset Home length *)
(* Send data register *)
S_BUF.BUFFER[0] := BYTE#16#11;
S_BUF.BUFFER[1] := BYTE#16#11;
(* Etc. ... *)
S_BUF.SIZE := 2; (* enter send length *)
state := 30;
30:
IF IP_C.ERROR <> 0 THEN
error:=IP_C.ERROR;
state := 00;
IP_STATE := 2;
ELSIF S_BUF.SIZE = 0 AND R_BUF.SIZE >= 0 THEN
R_BUF1.BUFFER := R_BUF.BUFFER;
(* evaluate received data *)
(* Logout - release access for other *)
IP_STATE := 2;
state := 00; (* process end *)
END_CASE;
IP_FIFO(FIFO:=IP_C.FIFO,STATE:=IP_STATE,ID:=IP_ID);
(*IP_C.FIFO:=IP_FIFO.FIFO;
IP_STATE := IP_FIFO.STATE;
IP_ID:=IP_FIFO.ID;*)
