I've problems with BLIND_NIGHT. This function block seems not to be working in my case. I've been connected to the PLC when the sunset comes and nothing happened
My code looks like this:
FUNCTION_BLOCK Blind
xBlindDown: BOOL;
xBlindUp: BOOL;
xAutoSunset: BOOL := FALSE;
xAutoSunrise: BOOL := FALSE;
tSunsetOffset: TIME;
tSunriseOffset: TIME;
xBlindControlUp: BOOL;
xBlindControlDown: BOOL;
BlindInput: OSCAT_BUILDING.BLIND_INPUT := (SINGLE_SWITCH := FALSE, MAX_RUNTIME := T#25S, MANUAL_TIMEOUT := T#60M, MASTER_MODE := TRUE, IN := TRUE);
BlindControl: OSCAT_BUILDING.BLIND_CONTROL_S := (T_UP:=T#20S, T_DN:=T#18S);
BlindNight: OSCAT_BUILDING.BLIND_NIGHT;
BlindSecurity: OSCAT_BUILDING.BLIND_SECURITY;
SunTime: OSCAT_BASIC.SUN_TIME := (LATITUDE := rLatitude, LONGITUDE := rLongitude);
CurrentDateTimeUTC: DATE_AND_TIME;
CurrentDateUTC: DATE;
And here is the code:
CurrentDateTimeUTC := FuGetDateAndTime();
CurrentDateUTC := TO_DATE(CurrentDateTimeUTC);
SunTime(UTC := CurrentDateUTC);
BlindInput(
POS:= BlindControl.POS,
S1:= xBlindUp,
S2:= xBlindDown,
//GVL.xInit is a global variable which is set to true after first PLC cycle
//this switch of IN state is required to stop moving of blinds after a power failure of PLC update
IF (GVL.xInit = TRUE) THEN
BlindInput.IN := FALSE;
END_IF
BlindNight(
UP := BlindInput.QU,
DN := BlindInput.QD,
S_IN := BlindInput.STATUS,
PI := BlindInput.PO,
DTIN := CurrentDateTimeUTC,
SUNRISE := SunTime.SUN_RISE,
SUNRISE_OFFSET := tSunriseOffset,
SUNSET := SunTime.SUN_SET,
SUNSET_OFFSET := tSunsetOffset,
E_NIGHT := xAutoSunset,
E_DAY := xAutoSunrise
BlindSecurity(
UP := BlindNight.QU,
DN := BlindNight.QD,
S_IN := BlindNight.STATUS,
PI := BlindNight.PO
// in order to stop moving blinds after a power failure or PLC update we need to check if PLC has been initialized
BlindControl(
UP := BlindSecurity.QU AND GVL.xInit,
DN := BlindSecurity.QD AND GVL.xInit,
S_IN := BlindSecurity.STATUS,
PI := BlindSecurity.PO
xBlindControlDown := BlindControl.MD;
xBlindControlUp := BlindControl.MU;
I also had a problem with the fact that after the power failure the blinds are going automatically up - I didn't want that is why I introduced the xInit global variable which is false by default and is set to true after the first PLC cycle. Thanks to this restart of the PLC is not moving the blinds up.
I was testing the whole code with IN := FALSE for BLIND_INPUT but it also didn't help, the BLIND_NIGHT was not working.
Do you see any obvious problems here?
Is there anyone who can share his code with the working BLIND_NIGHT function block?
I'm out of ideas what might be wrong?
Sorry but I don't speak German at all...
Hi dawrut,
I found some issues with BLIND_NIGHT when I started using it and more or less rewrote its code. Don't remember if your issue was among my findings (more than seven years ago), but if you want, you can try if my version fixes your problem.
Declaration:
FUNCTION_BLOCK BLIND_NIGHT
UP, DN : BOOL;
S_IN : BYTE;
PI, AI : BYTE;
E_NIGHT : BOOL := TRUE;
E_DAY : BOOL := TRUE;
VAR_INPUT CONSTANT
SUNRISE_OFFSET : TIME;
SUNSET_OFFSET : TIME;
NIGHT_POSITION : BYTE;
NIGHT_ANGLE : BYTE;
VAR_IN_OUT
CX : CALENDAR;
QU, QD : BOOL;
STATUS : BYTE;
PO, AO : BYTE;
night : BOOL;
last_night, last_day : DATE;
version 1.2 6 oct 2007
programmer hugo
tested by tobias
Code:
IF NOT (up AND dn) AND night THEN
night := FALSE;
ELSIF (cx.LTOD > cx.SUN_SET + sunset_offset) AND (last_night < cx.LDATE) AND NOT night AND e_night AND UP AND DN THEN
(* enable night *)
night := TRUE;
last_night := DT_TO_DATE(cx.LDT);
ELSIF (cx.LTOD > cx.SUN_RISE + sunrise_offset) AND (last_day < cx.LDATE) AND night AND e_day AND (last_night < cx.LDATE) AND UP AND DN THEN
(* disable night *)
night := FALSE;
last_day := DT_TO_DATE(cx.LDT);
IF UP AND DN AND night THEN
status := 141;
po := night_position;
ao := night_angle;
po := pi;
ao := ai;
status := s_in;
QU := UP;
QD := DN;
(* revision history
hm 29. sep 2007 rev 1.0
original version
hm 5. oct 2007 rev 1.1
added enable input
hm 6. oct 2007 rev 1.2
added pos and angle inputs and outputs
night position and angle can now be configured
any manual operation at night will cancel night operation
md 29 dec 2013 rev 1.3
added CX variable for sunrise, sunset and date and time information;
activated night program only if automatic mode is detected (i.e.
don't skip auto closing when in manual mode);
corrected missing QU/QD assignment when in night mode
md 12 jan 2015 rev 1.4
removed type conversion for TOD and DATE variables by directly
accessing cx.LTOD and cx.LDATE members
Please note that the block now uses one CALENDAR parameter instead of the SUNRISE, SUNSET and DT parameters. The calendar variable is fed by a CALENDAR_CALC FB instance which does some additional calculations I found useful. If you prefer the original style of dedicated parameters, you can easily change my code back to that approach.
Have you checked the times for sunrise and sunset calculated by SUN_TIME?
Cheers,
Thanks for sharing the code! I think I was able to fix the initial issue by a different combination of IN parameter of the Blind_Input function block. There are so many parameters that you can get lost... :D
The problem which right now I'm trying to solve is how to turn off the automatic calibration of the BLIND_CONTROL_S block. I put it into the VAR RETAIN PERSISTENT area but still when I upload a full version of the code to the PLC all the blinds go up. This makes me crazy!
I found some issues with BLIND_NIGHT when I started using it...
I come to the same conclusion. I thought that I initially fix the problems but I would need to rewrite the code. So I took your version and I'm testing it right now :)
The problem I was facing with my version was that:
- the blinds didn't move up in the morning
- in the morning I'm using BLIND_INPUT, I'm providing my value to the PI input and I'm assigning rising edge pulse to IN - this is moving blinds to a certain position. But the blinds which were previously closed by BLIND_NIGHT doesn't move to my position. Others work fine.
