oscat.lib => oscat.lib fuer TwinCAT/CoDeSys => Thema gestartet von: fbrauge in 09. April 2023, 09:09:00
Titel: "char" name used for a variable
Beitrag von: fbrauge in 09. April 2023, 09:09:00
dear,
I use codesys 3.5 SP19 with raspberry PI
There is a compilation warning
[WARNING] network, 1.3.5.2 (oscat): DNS_CLIENT(Line 26 (Decl)): C0543: The name 'CHAR' is a reserved keyword within the IEC61131-3 standard. An error will be reported in future versions.
As mentioned, in the future version of codesys, this  declaration will generate an error.
Could you correct the lib ?
thanks
