Hello,
I have tried the two FIFOs but the result is not as expected. When I start from zero I have the EMPTY output set.
I set WR=TRUE and give the E-input a pulse (one-scan). Now the FULL goes to TRUE and the EMPTY goes to FALSE as if it was a FIFO with one register in stead of 16(32).
The counters in the DB NW/NR do not move neither.
Any hint about what I am doing wrong?
Mfg
Hello,
there is a error in the code.
The line with the function INC1 is wrong.
Greetings Daniel
Hello,
Vielen Dank!
I do not have SCL, but I changed the STL-code and it seems to work perfect.
Once again thanks. I have just come across the library a short time ago and I am very happy about it.
Regards,
Olni
