oscat.lib for step7 TIA v11
Begonnen von gaspen, 01. Juli 2011, 22:11:00
gaspen
I do not understand any german so I write this in english.
I have been using oscat.lib in step7 for a while. Now that I have received the new TIA v11 I have started to convert the functions.There are mainly one difference which is that version in the header need to be without quotes ' . The code parser is also a little more strict but it will help you with where the errors are.
It will take a little while to convert the whole 3.22 library but if anyone is interested, I could make it available when I am finished with it.
tobias
yes of course we would be interested to add your translation to our pool
gaspen
I have now been able to convert the SCL code for all functions except FC399 DINT_DT and the functions depending on that. Some modifications were required on a few functions but I have not commented all those changes.
Next is to put all the functions in a library for TIA v11 and then I could upload it somewhere.
It is also possible to export the SCL as text but that can only be done function by function.
gkobler
Hello
I have migrate the OSCAT-Library 3.22 Basic from Step7 V5.5 Classic to the TIA11+SP1+Hotfix 1.
There was no fault durring the migration! But i didnt test it now!!
Gregor
gkobler
The complete OSCAT-Library Version 3.22 are now compiled without any fault. The migration should be complete!
Use it on your own risk!
Gregor
stud1
#5
beim Download der angezeigten Bibliothek bekomme ich lediglich eine index.php Datei (Dateigröße identisch). Natürlich kann ich diese auch einfach umbenennen, wobei ich die "Bibliothek" dann dennoch nicht in TIA V11 einfügen kann.
(Fehlermeldung)
Wäre sehr dankbar, wenn jemand eine funktionierende Datei hochladen könnte und/oder eine Anleitung verfassen könnte, wie man die BIB korrekt einfügt. (ggfs. ist die beschriebene Vorgehensweise von Siemens V11 nicht ganz korrekt)
Viele Grüße
gkobler
Du kannst die Datei downloaden und anschliessen von "index.php" in "irgend_ein_name.7z" umbenennen. Danach lässt sie sich mit dem 7-Zip Manager problemlos öffnen! (http://www.7-zip.org)
Anscheinend ist da noch ein Problem im Umgang mit Anhängen in diesem Forum.
Gregor
samus
Hallo!
ich habe leider ein Problem die Bibliothek in Step 7 Basic v11 einzufügen um den Baustein sun_time bei einem Projekt mit einer S7 1200 SCPU zu nutzen. Immer  wenn ich die Bibliothek einfüge und einen  Baustein öffnen will bekomme ich die Fehlermeldung das Step 7 Professional nicht installiert ist und kein Baustein kann geöffnet werden.
Könnte mir da vielleicht jemand  behilflich sein?
gkobler
Hallo samus
Gemäss Siemens geht bei TIA V11 Basic nur KOP und FUP, für OSCAT benötigst du aber SCL! Da benötigst du die Professional Version!
STEP 7 Basic V11 bietet die IECProgrammiersprachen KOP (Kontaktplan)und FUP (Funktionsplan).
Gregor
Dettenrocks
Ich möchte den Baustein Temp_PT[FC347] gerne für meine S7-1200 nutzen. Leider bekomme ich die Fehlermeldung "Der Operand ... ist nicht definiert"
Was muss ich ändern damit das Funktioniert?
#step := 50.0;
#X := "A_FC347" * #R0;
#Y := "B_FC347" * #R0;
IF #Res >= #R0 THEN
    #t1 := #X * #X - 4.0 * #Y * (#R0 - #Res);
    IF #t1 < 0.0 THEN
        #TEMP_PT := 10000.0;
        #TEMP_PT := (-#X + SQRT(#t1)) / (2.0 * #Y);
    (* since the formula cannot be solved this is a successive approximation *)
    #TEMP_PT := -100.0;
    WHILE #step > "accuracy" DO
        (* test if result greater or less *)
        IF "RES_PT"(T:=#TEMP_PT,R0:=#R0) < #Res THEN #TEMP_PT := #TEMP_PT + #step; ELSE #TEMP_PT := #TEMP_PT - #step; END_IF;
        (* pt^ := pt^ - 8388608; *)  (* this is a super fast divide by 2 method for non floating point CPUs *)
        (* the alternative code: step := step * 0.5; *)
        #step := #step * 0.5;
    END_WHILE;
Manuel_
Zitat von: gkobler in 17. August 2011, 08:16:56
Hello
Gregor
Hallo Gregor,
wie hast du die Bausteine in V11 migriert? Hast das ganze Projekt oder die einzelnen Quellen migriert? Bei mir macht V11 immer Reihenweise Fehlermeldungen beim importieren von Quellen aus V5.5.
Manuel
gkobler
Hallo Manuel
Ich habe die gesammte Library ins TIA11 übernommen und auch übersetzt. Dabei ist sehr viel Handarbeit nötig (ca. 2-3 Tage). Auch musste ich mehrmals einen Service-Request bei Siemens machen, da ich damals nicht weitergekommen bin.
Ich hatte damals versucht mich in das TIA-Protal einzuarbeiten. Ich habe es dann aber sein lassen, da es meiner bescheindenen Meinung noch viel zu Unreif ist und auch eben noch viele Fehler beim Mirgiren macht. Ich musste vieles von Hand korrigieren, wo ich der Meinung bin das es eigentlich auch automatisch gehen müsste!
Vielleicht kann man irgenwann mal TIA ab Version 20 gebrauchen.  :(
Nimm als Basis meine Verison, die lässt sich zumindest mal ohne Fehler übersetzten!
Gregor
knuetterich
#12
Zitat von: samus in 13. September 2012, 10:51:29
Hallo!
Hallo Gregor,
ich habe dasselbe Problem wie Samus. Bei mir kommt auch diese Fehlermeldung.
Das V11 Basic kein SCL kann, kann ich nicht bestätigen. Habe selbst schon Bausteine in SCL geschrieben.
Aktuell habe ich die Version V11 SP2 Upd5.
Gibt es hierzu vielleicht neue Erkenntnisse?
Ralf
gkobler
Hallo Ralf
Einen Auszug auf der Siemens Homepage:
SIMATIC STEP 7 Basic V12 ist ein preisoptimiertes Subset der STEP 7 Professional Controller Software im TIA Portal, das sowohl für das Engineering der SIMATIC S7-1200 Micro Controller und die Projektierung der SIMATIC HMI Basic Panels genutzt werden kann, da WinCC Basic Teil des Software Pakets ist.
Dank seiner Integration in das Engineering Framework des TIA Portals bietet SIMATIC STEP 7 Basic die gleichen Vorteile wie die STEP 7 Professional Engineering Software z.B. direkte Online Diagnose, einfaches Hinzufügen von Technologie-Objekten oder auch das Bibliothekskonzept für zeitsparendes efiizientes Arbeiten und Widerverwendbarkeit von Daten.
STEP 7 Basic V12 bietet die IEC Programmiersprachen KOP (Kontaktplan), FUP (Funktionsplan).und SCL (Strukturierter Text)
Was mit der V11 ist , kann ich dir nicht sagen, aber vermutlich das gleiche wie bei V12. Aber hast du Step7 Classic? Oder das TIA-Protal? Bei Step7 Classic ist SCL nur in der Professional Version enthalten.
Gregor
knuetterich
#14
Hallo Gregor,
ich benutze sowohl Step7 V5.5 Classic als auch TIA-Portal V12 Professional (seit Montag).
Nachdem ich die Bibliothek in V12 Professional geöffnet hatte, funzte alles sofort.
Kompliment!!
Ich verwende die Bibliothek momentan für ein S7-1200 Projekt.
Dabei musste ich feststellen, dass einige Bausteine aus der Bibliothek Fehler hervorrufen.
Das liegt daran, dass einige dieser Bausteine (Datums- u. Zeitfunktionen) den S7-300/400-Datentyp DATE_AND_TIME verwenden.
Die S7-1200 kennt diesen Datentyp aber nicht. Statt des DATE_AND_TIME Datentyp wird hier der Datentyp DTL verwendet (das versteh wer will...Siemens eben  :-[).
Der Datentyp DTL hat 12 Byte anstatt 8 Byte beim DATE_AND_TIME Typ.
Der Datentyp DTL ist folgendermaßen aufgebaut:
Wort 0:   Year (UINT)
Byte 2:   Month (USINT)
Byte 3:   Day (USINT)
Byte 4:   Weekday (USINT)
Byte 5:   Hour (USINT)
Byte 6:   Minute (USINT)
Byte 7:   Second (USINT)
Dwort 8: Nanosecond (UDINT)
Gibt es hierzu schon eine Bibliothek speziell für die S7-1200 die in den Datums- u. Zeitfunktionen den Datentyp DTL verwenden?
Wäre über Hilfe echt dankbar!!
Ralf
