Problehm mit function DT_TO_STRF
Begonnen von toonvl, 26. Juni 2012, 10:47:57
toonvl
First of all sorry I'm using english, but my german really isn't good enough to explain a problem.
I'm trying to use the oscat library function 'DT_TO_STRF' but I'm having some problems.
When I am trying to get the date in the returned string, the month is always empty, and so are the hours and the minutes. I have tried to use different formats for months and minutes ( #C, #D, #E and #F ) but all give 0 or 00. Same goes for the minutes and hours. I do have changed the language DB, I've added an extra fourth language ( Dutch ), but I've changed everything correctly I think, I've specified the max as 4 for every array, as wel as the max variable in the DB. Also when I tried to get all the possible formats ( #A to #X ) it got stuck at the second or third format which kept on reapeating ( 1990909090909090909090990 or something was the result ).
Right now I'm trying a workaround to get the date and time displayed in WinCC, but I'm a little dissapointed as this function did exactly what I needed. :(
Can anyone guess what I could be doing wrong?
Thanks in advance!
Kind regards,
Toon Van Lishout
Fussel0804
Hi!
Du brauchst die FUnktion nicht.
WinCC kann DT direkt anzeigen.
Gruß Stefan
Wenn du weitere Fragen hast, melde dich
