AIN1
Begonnen von shooter, 13. Dezember 2012, 20:24:33
shooter
wenn auch negativ signale wie bei wago -10/+10V input benutzt werden muss der letzte regel geandert worden in
IF sign THEN out:= out - out_max; END_IF
so with this change it will be AIN2 (done in my system
shooter
(* @NESTEDCOMMENTS := 'Yes' *)
(* @PATH := '\/Engineering\/signal processing' *)
(* @OBJECTFLAGS := '0, 8' *)
(* @SYMFILEFLAGS := '2048' *)
FUNCTION_BLOCK AIN2
   in : DWORD;
VAR_INPUT CONSTANT
   sign_bit : INT := 255;
   error_bit : INT := 255;
   error_code_en : BOOL;
   error_code : DWORD;
   overflow_bit : INT := 255;
   overflow_code_en : BOOL;
   overflow_code : DWORD;
   Bit_0 : INT;
   Bit_N : INT := 31;
   out_min : REAL;
   out_max : REAL := 10.0;
   code_min : DWORD;
   code_max : DWORD := 16#FFFFFFFF;
   error_output : REAL;
   overflow_output : REAL := 10.0;
VAR_OUTPUT
   out : REAL;
   sign : BOOL;
   error : BOOL;
   overflow : BOOL;
   tB: DWORD;
version 1.3   10. mar. 2009
programmer    oscat
tested by      tobias
Ain2 converts positiv and negativ signals from A/D converters or other digital sources to an internal real value.
(* @END_DECLARATION := '0' *)
(* extract error bit *)
error := ((SHR(in,error_bit) AND 16#0000_0001) = 1) OR (error_code_en AND error_code = in);
IF error THEN
   out := error_output;
   RETURN;
(* strip off the data input *)
tb := SHR(SHL(in, 31 - bit_N), 31 - bit_N + Bit_0);
(* extract overflow bit *)
overflow := ((SHR(in,overflow_bit) AND 16#0000_0001) = 1) OR (overflow_code_en AND overflow_code = in) OR (tb < code_min OR tb > code_max);
IF overflow THEN
   out := overflow_output;
   RETURN;
(* extract sign bit *)
sign := (SHR(in,sign_bit) AND 16#0000_0001) = 1;
(* convert in to out *)
out := (DWORD_TO_REAL(tb - code_min) * (out_max - out_min) / DWORD_TO_REAL(code_max - code_min) + out_min);
IF sign THEN out := out-out_max; END_IF;
(* revision history
hm   23. feb 2008   rev 1.0
   original version
hm   16. mar 2008   rev 1.1
   added type conversions to avoid warnngs under codesys 30
hm   22. apr. 2008   rev 1.2
   corrected error in formula when code_min was set
   corrected error when sign bit was used
   optimized code for better performance
hm   10. mar. 2009   rev 1.3
   real constants updated to new systax using dot
END_FUNCTION_BLOCK
shooter@home.nl
shooter
i have changed the calcs to be conform.
added a thinker to change the maxcode as this is also embedded in bit_0 and BIT_N
FUNCTION_BLOCK AIN2
   in : DWORD;
VAR_INPUT CONSTANT
   error_code : DWORD;
   Bit_0 : INT;
   Bit_N : INT := 31;
   out_min : REAL;
   code_min : DWORD;
VAR_OUTPUT
   out : REAL;
   sign : BOOL;
   error : BOOL;
   overflow : BOOL;
   tB: DWORD;
programmer    oscat
tested by      tobias
IF error THEN
   RETURN;
IF overflow THEN
   RETURN;
(* revision history
   original version
pd 16 dec 2012
   added 2 complement and proposition to remove max code
END_FUNCTION_BLOCK
