ACTUATOR_PUMP
Begonnen von Andrey, 18. Oktober 2007, 15:10:54
Andrey
How i can use ACTUATOR_PUMP for 2 or 3 pumps??
And  if i insert in "min_on_time" or "min_off_time" parameters value (example) DB110.DBD0 ( Time) - this not worked.
Sorry.
Ich lerne Deutsch aber spreche nicht. Entschuldigen bitte
english is fine dont worry.
first of all, for more then oe pump simply use multiple instances of actuator_pump
the setup times pls specify in capital letter T#100ms for example
Andrey
Thanks
And how i can change this time from panel?
double click on the symbol in your design editor and a table opens where you can change the values
