ONTIME TIA V13 S7-1517F
Begonnen von wim.cranen@wccandm.nl, 01. Juli 2015, 16:11:08
Guten Tag, die Damen und Herren.
Good day, ladies and gentlemen.
Wer hat der Baustein ONTIME schon verwendet unter TIA Portal V13, auf eine SPS S7-1517F?
Frage: funtioniert der Baustein?
Wo has used the ONTIME block under TIA Portal V13, on a PLC S7-1517F?
Q: are the results ok?
Greetz, Wim.
shrimps
Hello,
i am using Ontime in Twincat(Codesys) for about 3 Months and it works fine.
Sorry, no Siemens...
Regards
Shrimps
mg
#2
On 1511 and 1513 it works.
But I have a Problem when I make a firmware-update or complete Download.
All my hours are away.
So as long you do not reset you PLC it works fine.
Take attention at: www.oscat.de/community/index.php/topic,2244.0.html when you have other PLC's (eg. 300)
Mg
Thanks,
I've tested ONTIME and T_PLC_MS on a S7-1517F and they are ok.
Before firmware update, always make a backup of the system to save actual values.
And indeed, if you do a complete download, all your memory wil be reset to default.
Greetz, Wim.
