DEC_TO_BYTE problem
Begonnen von automatizator, 30. September 2008, 10:02:06
automatizator
I apologize if writing in English is not acceptable, but I only understand German enough to read the posts...
I think there might be some wrong checking in the various conversion functions, such as DEC_TO_BYTE, DEC_TO_DWORD, DEC_TO_INT and so on, at least in the plaintext version of the library (oscat276.txt). The IF clause
"IF X > 47 AND x < 56 THEN"
appears in them, but if you check the ASCII table you'll see that it should probably read
"IF X > 47 AND x < 58 THEN"
otherwise characters '9' and '8' will not be evaluated.
we will check immediately and correct in version 277 if necessary
thx for the input
ps dont worry about english, its no problem for us
thanks very much for the input,
the mentioned functions had a serious problem and will be corrected with the next release 2.77
Jicin
das gleiche Problem ist auch in der Funktion FLOAT_TO_REAL.
Auch hier wird leider immer die 8 und die 9 ignoriert.
Ja hier ist leider auch der gleiche Fehler mit drinnen
wird auch mit der release 2.77 behoben
danke..
