Hello,
I would like your help.. DT_IN i give GVL.XCAL.LDT from calendar_calc function block. Until here ok but when i run the program and i go online, on the beginning(of thread) is shows the local time that gets from global variable as we said and on the on the input of timer_ext fb its shows DT#1970-1-1-0:0:0. Even though these 2 are directly connected , FB doesnt take the LDT.
Thank you in advance.
